Re: how to change watery hy-tran fluid in 560
Posted by tbish on December 28, 2013 at 03:39:15 from (50.40.163.4):
In Reply to: how to change watery hy-tran fluid in 560 posted by sam crowley on December 27, 2013 at 19:32:38:
I would drain it and take a line off power steering pump and hydraulic and your 2pt hitch start it and work your controls a couple of times to push out as much fluid as possible don't run it but just a few seconds or u may burn your pumps up when u refill your going to have to bleed your system put your lines back on leave the fittings loose so air can escape work your controls until you get just fluid no air then tighten fittings prob got water setting out over the yrs or condensation hard to say with a 50yr old tractor rain will seep in when a tractor sets out
