Posted by Zachary Hoyt on December 28, 2013 at 11:16:18 from (184.8.251.166):
In Reply to: I broke it! Please Help posted by Dave8N in Pa on December 28, 2013 at 11:10:17:
I would say you could be in two gears, to check just knock out the pin or remove the bolt and pull out the shifter. You can see the slots where the shifter tip rides and see if they are all lined up. Sounds to me like you could have damaged the constant mesh gears in the transmission so they are unable to turn, or maybe the PTO is not disengaging inside. If the tractor is in neutral when you check then I think the problem has to be in the input shaft, hydraulic pump, PTO or countershaft areas since they are all that is connected to the engine when you let out the clutch in neutral.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
