Re: Broken Flywheel while removing ring Gear
Posted by farmallhal on December 28, 2013 at 14:23:32 from (76.2.174.165):
In Reply to: Broken Flywheel while removing ring Gear posted by yoyo27983 on December 28, 2013 at 13:43:30:
Any machine shop I have ever dealt with would have replaced it with an undamaged one before returning it to me. An undamaged flywheel can easily be found off of a salvage tractor with a little effort. By cracking off the edge you very likely have a small crack somewhere along the broken edge which will migrate into the center and result in a multi-piece flywheel over time and require replacement later if not resolved at present. I don't have a feel of how much additional wear would be transmitted to the rear main bearing due to the out of balance caused by the ring gear damage but others will probably have some input as I don't know how well balanced they were to begin with, Hal.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
