Re: Broken Flywheel while removing ring Gear
Posted by Janicholson on December 28, 2013 at 15:47:59 from (208.53.222.178):
In Reply to: Broken Flywheel while removing ring Gear posted by yoyo27983 on December 28, 2013 at 13:43:30:
12" of weight at the edge is too much imballance in my opinion. They need to machine the remainder off and clean up the broken surface. Pinning the ring gear on if it is at all loose is also a good idea. If that much weight was needed on a tire, you would get a different tire, not run it out of balance. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
