Parts could be described better on this site for the wheel bearings. But look on 400 parts for wheel bearing kit FW-112-FS if wanting a complete kit. For individual pieces look for the numbers in the kit. First remove the outer bearing to make sure of the number. If replaced sometime the outer race and bearing may be different than original. Outer bearing and cone type needs to match.
Listings showing the same bearings for H and M need to say with old style wide front. Tie rods in front of the axle.
Also the wheel casting number will help getting the correct parts. Wheel with 3 steel clamps attaching the rim is 6803. Wheel that uses a rim with 3 loops bolted to wheel is 8284. Need the suffix letters to know for sure what bearings came in the wheel. Like others said see what the problem is and the parts needing replaced and numbers on old parts if found.
This post was edited by D Slater at 18:09:42 12/28/13.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
