Re: Farmall M Narrow Front End Wheel Bearing Kit
Posted by SDE on December 28, 2013 at 17:31:25 from (174.124.52.81):
In Reply to: Farmall M Narrow Front End Wheel Bearing Kit posted by nate_o23 on December 28, 2013 at 16:00:12:
If only one side is wobbling badly, then the problem is on just that side. Jack the front up and push in at the top and out at the bottom. A bunch of movement would indicate a loose bearing. Tighten it up and reinspect. If the bearing is tight and you still have movement, the bearing maybe bad. The bolts holding the rim to the wheel may be loose also. These are things to check before you order parts.
SDE
