Re: Broken Flywheel while removing ring Gear
Posted by SDE on December 28, 2013 at 17:39:48 from (174.124.52.81):
In Reply to: Broken Flywheel while removing ring Gear posted by yoyo27983 on December 28, 2013 at 13:43:30:
If you want the machine to stand behind their work, then lean on them a little. If they have a lathe the will handle turning it, it would not take hardly any effort at all it trim enough off of it all the way around to even everything up again. You paid them to do an easy job. They should have been able to do it correctly. Did they heat it up to put it on, or did they use a press? If they pressed it on, they did it wrong.
SDE
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
