Re: how to change watery hy-tran fluid in 560
Posted by d282 on December 29, 2013 at 10:56:15 from (166.181.80.8):
In Reply to: how to change watery hy-tran fluid in 560 posted by sam crowley on December 27, 2013 at 19:32:38:
Drain the oil out of the three drain holes plus the filter housing. Put the plugs back in with a new filter and fill it with 17 gallons of diesel and drive around for ten minutes. I also loop a hydraulic hose from the valve outlets to flush them with diesel.
Park tractor and let it drain for a few days. Replace filter again, put in plugs and fill with hy-tran and you are good to go. The little bit of diesel in the lines will not hurt anything. Good luck.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
