Re: 560d high rpm miss
Posted by rustred on December 29, 2013 at 13:09:16 from (74.214.152.80):
In Reply to: Re: 560d high rpm miss posted by tbish on December 29, 2013 at 12:26:21:
the pump will not make it pop, it has to be in the valve train. have you checked that? when did this popping start?
but then your popping description may be totally different than what I call popping. when you have a worn cam lobe it will pop through the intake.
yes there is fuel adjustments, but tractor should be on dyno for that. why was pump taken off? what was done to it? give complete story.
