Re: farmall c dies after a few seconds of running
Posted by gene bender on December 29, 2013 at 13:35:29 from (207.177.56.213):
In Reply to: farmall c dies after a few seconds of running posted by farmallboy15 on December 27, 2013 at 16:28:23:
If the engine runs a few seconds the bowwl is not full of gas as you can turn the gas off at the tank and it will run for more than a few seconds you arent getting gas thru the carb . First remove the carb with gas line still attached and then remove the line to soo how much flow you have. The reason for removing carb with gas line still attached it is easier to rethread the fitting back this will elinate cross threading when re attaching the line as you probably will need to remove the carb anyway.
