Re: Questions for the experts..
Posted by Red Dave on December 29, 2013 at 17:12:48 from (174.59.201.239):
In Reply to: Questions for the experts.. posted by Blackriver on December 29, 2013 at 16:46:20:
I would take "Super C pistons" to mean 3 -1/8 diameter pistons, they would increase the displacement to 123 cu in. Yes, you can put 3-1/8 pistons in a C-113 block, but you must use sleeves that are made for that purpose. The sleeves that are in the Super C block may work, but I am doubtful as the outside dimensions of the sleeves are probably too large for your block.
The critical measurement is at the bottom of the sleeve, where the "O" ring seals. You need to know the I.D. of the hole at that point, and the O.D. of the sleeves at the same point. There are at least 2 different diameters that were used, depending on whether the engine came from the factory as a C-113 or C-123.
If the pistons are flat top, your head will work fine too. If they are high compression step head, or firecrater pistons, there may be interference issues to be worked out. I have had to machine a little out of heads to make room for high compression pistons. I have no way to tell if you will have that problem or not.
You can get sleeves that will fit your block and allow you to use the 3-1/8 pistons. They are usually bought as sets, in a kit.
You can piece this together and make it work, but you will have to do some measurements to find out what block you have and what pistons & sleeves you have.
I have put Super C pistons in a "B" block, but the sleeves were made as thinwall sleeves so they would fit.
