Re: Using a fire wrench?
Posted by Pete in Holland MI on December 29, 2013 at 17:19:08 from (192.132.24.74):
In Reply to: Using a fire wrench? posted by Kellyc on December 29, 2013 at 15:04:55:
Heat up the clamp. You're trying to raise the temperature of the rust at the threads to above 500-800F degrees to break it down. Does not need to be red hot. Heat it up, add some light oil or ATF, and try turning it.
