Re: 560d high rpm miss
Posted by Dieseltech on December 29, 2013 at 18:09:40 from (199.16.223.2):
In Reply to: Re: 560d high rpm miss posted by tbish on December 29, 2013 at 17:26:25:
X 2 what pete said. If you can get it on a PTO dyno it can be set accurately. I use the batwing gauge, but the window works too, just harder to see. Should be full retard at full load, full 4 degrees at no load and 2 degrees at 1/2 load. If it does stay retarded at all times it will pop badly at no load, and sound fine at full load. Be careful when locking the stud nut, housing threads can be stripped easily.
