Posted by S2710 on December 29, 2013 at 18:35:55 from (207.190.76.146):
In Reply to: Using a fire wrench? posted by Kellyc on December 29, 2013 at 15:04:55:
Kelly it is steel bolt into cast so it should not be froze to bad. I had a h this last year that many years ago leaked CC down on the bolts and the bolts were rusted solid in the wheel I heated the casting up and they broke loose and when I got them out over half of the diameter of the bolt was gone. I had steady pressure on the bolt when I was heating it and when it moved I went back and forth till most of the rust fell out.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
