Re: Farmall M Narrow Front End Wheel Bearing Kit
Posted by GeneMO on December 29, 2013 at 19:12:09 from (71.51.202.146):
In Reply to: Farmall M Narrow Front End Wheel Bearing Kit posted by nate_o23 on December 28, 2013 at 16:00:12:
Yep, drive it up on a board, one wheel at a time and shake the heck out of each wheel. You can get wheel bearing and races at NAPA.
But if the whole front end is shimmying, then it is probably in the worm gear up top in the bolster. This assemply can be reversed or swapped over to make it use the unworn part.
Gene
