Re: I broke it! Please Help
Posted by mkirsch on December 30, 2013 at 06:30:24 from (65.199.189.6):
In Reply to: I broke it! Please Help posted by Dave8N in Pa on December 28, 2013 at 11:10:17:
If the transmission was in neutral when it happened, then it's not stuck in two gears.
Something came apart and got jammed in the gear train. Probably a ball bearing slipped out of its races and dropped down between two gears.
You might be able to get it to "spit out" whatever's jammed in there by putting the tractor in a forward gear, and pulling it backwards with the clutch pedal pushed. If it doesn't start rolling right away, don't try to force it.
Otherwise you're going to have to figure out some way to skid it back home on logs or slide it up on a trailer or something to get it out of the field.
If it was a Super H you could pull one of the bull pinions which would completely disconnect the differential from the transmission, which should allow it to roll in most cases.
