Re: Super M trans
Posted by Brian Schmidt on December 30, 2013 at 13:16:40 from (69.66.237.150):
In Reply to: Super M trans posted by Chester5731 on December 30, 2013 at 11:56:51:
It really depends on the temps in which you will be operating in.
If in high ambient temps, 95F+ under high loads, I would go 85w-140.
If operating at lower loads at lower ambient temps, I would go with 80w-90.
The heavier oil may not leak quite as much as the lighter oil. But simply swapping oils between the two won't make that much difference in a leak or not.
