Re: Re: Help!!! Super M Engine oddity
Posted by Pete on December 13, 2000 at 05:25:13 from (32.97.239.18):
In Reply to: Re: Help!!! Super M Engine oddity posted by The Red on December 12, 2000 at 16:45:02:
Red-
I made a typo-I DID hook up the wires according to the book and the block (1342) firing order. Also checked to be sure that the distributor wasn't 180 degrees off. Checked timing. Wouldn't run according to proper firing order. Will only run when hooked up in reverse of firing order. So, is it possible that the cam isn't timed to the crank properly or is there something else I should be looking at?
Thanks
Post A Followup
: Re: Re: Re: Help!!! Super M Engine oddity
