Re: Pull starting a 1951 C
Posted by old on January 01, 2014 at 12:41:51 from (209.86.226.11):
In Reply to: Pull starting a 1951 C posted by michael bailey on January 01, 2014 at 10:37:06:
So it has sat a month with out running right?? If yes pull the distributor cap off the rotor and dust cover then turn on the ignition. Carefully open and close the point by hand. Reason I say carefully is you can get a good zap if you do it wrong. Make sure you have a spark that the points that you can both hear and see. Good chance the points are corroded a little bit and that is enough to kill your spark and no spark no run
