Posted by LeeinIL on January 01, 2014 at 13:11:32 from (166.182.82.233):
In Reply to: Re: 986 pto problem posted by ziemerj on January 01, 2014 at 12:51:03:
You may need to adjust your spool linkage on the PTO housing. There is a pressure port on the side of the housing to check your pressure, if your pressure is correct then your clutch packs are probably worn out. If you cannot adjust your pressure then you may have a bad pump or seals leaking on the piston. There is also a seal on the pickup tube that could be leaking and not allowing the pump to pick up enough oil to work properly. The pump is contained on your PTO housing. Use a good manual to for correct pressures. Rebuilding the PTO is not a horrible project to complete, a little tedious but not bad.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
