Re: farrmall rear end question
Posted by baldwin racing on January 01, 2014 at 18:38:54 from (74.79.154.169):
In Reply to: farrmall rear end question posted by Taylor88 on January 01, 2014 at 15:51:54:
measure and mark the length you want and cut them with a portaband or a demo saw just have some one running collant or water over axle tord the seals? to keep axle cool so it don't mess up the seals if out of the tractor could cut them on a band saw with collant.... take a grinder and just round off edge a little or if out of tractor chuck in a lathe and round end off a little....
Kelly
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
