Re: IHC 404 #2 Cylinder Missing
Posted by Kent in Michigan on January 02, 2014 at 06:06:17 from (173.167.4.51):
In Reply to: Re: IHC 404 #2 Cylinder Missing posted by Kent in Michigan on December 29, 2013 at 03:55:19:
Well, that wasn't hard. Runs good, no obvious reason for the bent rods, must have been ice. Interesting note, the valves had NO lash gap as I found them. Wondering if I should go back and check them all agian after a few hours of running.
Thanks for the help.
