Re: Help Identify Super A Broken Part
Posted by Zachary Hoyt on January 02, 2014 at 08:40:10 from (184.8.251.166):
In Reply to: Re: Help Identify Super A Broken Part posted by asyrp43 on January 02, 2014 at 08:35:29:
That is the ballast resistor. It reduces the voltage to the coil from 12v to 6v. It is widely available at auto parts stores, TSC etc. Just take the old one in with you and show it to the parts guys and they should be able to get you one.
Zach
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
