Posted by gene bender on January 02, 2014 at 09:10:03 from (207.177.56.213):
In Reply to: Farmall Super A lights posted by Tim F Zera on January 02, 2014 at 07:53:52:
Super A has a regulator so the three position sw is used. You need two wires going to the reg area one is for batt volts the other is for the two lites. Another wire from the amp guage to the starter and one going from the sw to rear lite. Then one going from the ign sw to the coil and another from the amp guage to the sw. Some sleeve covering and some terminal ends and you have it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
