Re: Repowering a Super M Farmall
Posted by mkirsch on January 02, 2014 at 11:23:22 from (65.199.189.6):
In Reply to: Repowering a Super M Farmall posted by Dave Fugate on January 02, 2014 at 10:47:17:
I would be genuinely surprised if somebody has done that EXACT conversion. The possibilities are literally endless.
Generally speaking, the conversion process is the same:
1. Remove the old engine.
2. Design and fabricate a rear engine mounting plate to locate the engine properly in the bell housing.
3. Modify frame rails as necessary, longer and/or wider depending on the engine. Ideally shoot for having the tractor the same length as original.
4. Probably machine a flywheel so the clutch matches up.
5. Connect linkages, hoses, and wiring.
