Re: injection nozzle design
Posted by Dieseltech on January 02, 2014 at 11:33:48 from (98.206.80.148):
In Reply to: injection nozzle design posted by mazemeister on January 02, 2014 at 10:18:22:
IH D282 do not need return lines as the nozzle valves are outward opening, not inward like the 361/407 injectors. Higher opening pressures do help with atomization, but is harder on pumps also unless designed for increased pressure load. There are many newer engines with 3500 to 4500 PSI opening pressure, and some still use Stanadyne and other rotary pumps just fine.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
