Re: Help Identify Super A Broken Part
Posted by farmallhal on January 02, 2014 at 15:18:37 from (76.2.170.178):
In Reply to: Help Identify Super A Broken Part posted by asyrp43 on January 02, 2014 at 08:28:48:
I am not a 6 to 12 volt conversion expert as I have only converted a single Farmall H in that manner. The resistor I used (which worked great) was a RU12. The one thing I wanted to advise you on if your newly installed resistor behaves in the same manner as mine did expect some significant white smoke rising above the resistor when the tractor is started the first time. I believe it is from some protective coating burning off the wound wire which forms part of the resistor. One good thing is they are very inexpensive and will likely be one of the lower cost items you will have to purchase for your restoration. Have fun and enjoy the project, Hal.
