Re: injection nozzle design
Posted by jdemaris on January 03, 2014 at 05:12:25 from (70.194.6.138):
In Reply to: injection nozzle design posted by mazemeister on January 02, 2014 at 10:18:22:
Some injectors are intentionally designed to pass a small flow of diesel fuel through them to keep them lubricated. So are just about all mechanical fuel injection pumps.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
