Re: MD fuel injection while running on gas
Posted by pete 23 on January 03, 2014 at 10:19:14 from (74.33.68.83):
In Reply to: MD fuel injection while running on gas posted by PASteve on January 03, 2014 at 06:37:19:
I agree on the adjustments of the lever on pump. A quick check though is to open all the bleeders on the injection nozzles while running on gasoline. This will stop any fuel from opening the nozzles to prove weather or not diesel fuel is injecting while on gas cycle. The pump has no definite shut off in reality, it only rotates the plunger spill port to the point where not enough pressure builds to open the nozzles when in shut off position. That is also adjustable on the rack itself if need be.
