Posted by rustyfarmall on January 03, 2014 at 10:56:44 from (208.126.186.41):
In Reply to: m farmall alternater posted by Bob M on January 03, 2014 at 10:44:32:
The Delco alternator that someone installed on my M did not fit completely under the hood. When I investigated, I found they had used the aftermarket, universal mounting bracket, and they had also used a belt that was too long. Since I didn't have an original generator mounting bracket, I modified the existing universal bracket so the alternator sat a little higher, and then I was able to use an original, replacement generator belt. That Delco alternator now sets right where it is supposed to set, the belt is tight, and it clears the hood with room to spare.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
