Posted by mkirsch on January 03, 2014 at 12:00:37 from (65.199.189.6):
In Reply to: m farmall alternater posted by ohiojim on January 03, 2014 at 10:08:55:
You don't even need a special bracket.
Just flip the stock bracket over, and mount the new alternator AHEAD of the bracket, using a 3/8" all thread running through both holes in the bracket.
You may need to shave 1/4" or so off the rear of the alternator's bottom mounting lug, depending on the alternator you get. Basically you just cut it at the casting line with a hacksaw.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
