Posted by old on January 03, 2014 at 12:43:31 from (209.86.226.27):
In Reply to: m farmall alternater posted by ohiojim on January 03, 2014 at 10:08:55:
I have done more then one using the common Delco alternator. You just need to flip the bracket and use a shorter belt and it can be done pretty easy. Last one I did I used the same alternator as is used on my 1980 Chev pick up
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
