Posted by 2 pipe on January 03, 2014 at 17:09:23 from (198.45.167.21):
In Reply to: m farmall alternater posted by ohiojim on January 03, 2014 at 10:08:55:
I always use the GM one wire alternator and flip the original bracket over, it works great. They also make that same kind of alternator in a smaller case which will give you just a little more room. Either one will work on an M or H though. Good luck!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
