Re: Need help Super A will not speed up
Posted by old on January 03, 2014 at 18:00:46 from (209.86.226.56):
In Reply to: Need help Super A will not speed up posted by Robert Howle on January 03, 2014 at 17:01:35:
Could be a number of things. If you grab the gov to carb rod and move it by hand will it spin up and if yes does the gov hold it back?? If it spins up good but the gov tries to hold it back check the throttle linkage to the gov and make sure it is hooked up and not binding. One that this can be hard to explain so follow the linkage and make sure all is good and no parts bind or have missing springs etc
