Posted by TedinNE on January 03, 2014 at 20:26:01 from (63.172.255.207):
In Reply to: Re: 706 transmission posted by Rmf1066 on January 03, 2014 at 20:08:38:
Have you checked the reverse shift fork. It is easy to inspect, just remove the side plate on the left side. The lower end of the fork can break off. Also check how much end play you have between the gears & shift collar on the reverse idler shaft. Have seen the rear thrust washer wear into the housing. Collar can't fully engage the gear. Sounds like you have checked the top end & cover pretty well. Any excess wear in the linkage will make it hard to get reverse. A worn bushing in the shift lever and the pin it pivots on looses travel needed to shift into the gears.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
