Re: Wiring on a Farmall 140 12v Conversion
Posted by charlieu on January 04, 2014 at 10:38:22 from (209.131.225.223):
In Reply to: Wiring on a Farmall 140 12v Conversion posted by RTR on January 04, 2014 at 08:56:56:
The wiring diagram that you posted is a 6 volt system. The battery only has three cells. I agree with Janicholson, those one wire alternators can a problem at times. I like the Hitachi alternator as it starts charging at low speed.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
