Re: Wiring on a Farmall 140 12v Conversion
Posted by soundguy on January 04, 2014 at 12:05:55 from (207.30.46.70):
In Reply to: Wiring on a Farmall 140 12v Conversion posted by RTR on January 04, 2014 at 08:56:56:
i'd dyke that mess out and just rewire with 14awg.
only takes a few feet of wire to wire up charge system, ignition and starting and lamps.
just not that much copper needed on an old farm tractor like that.
I make ALL my own harni'
nothing EVER gained in chopping up one from 1950 nd wondering if it will work or not.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
