Posted by Brownie 450 on January 04, 2014 at 14:16:34 from (66.43.241.198):
In Reply to: Super MTA troubles posted by LaDuke Farmall on January 04, 2014 at 12:03:19:
If after doing the checks already listed, & the trouble persists, check the coil primary wire where it goes up over the valve cover [in the harness]. Our SMTA had the wire down to 2 strands conducting where it went through a clip on the front valve cover bolt/ stud. It would act just as you are describing yours is. We figured the 2 strands would conduct until they got hot & then the resistance would rise & choke off voltage to the coil. You can check for this by running a wire with clips from the battery to the coil temporarily. Sounds like maybe a bad condenser, though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
