I'm with you SoundGuy, but since the wiring on this tractor is still in good shape and all connections are still there, I figured I would see if there was an easier way (ie. connect green to alternator "bat" and yellow and white to #1 and #2, then leave all other connections unplugged). Also, if someone else wanted to change it back to the original config., the wires would still be there.
*(That is just an example of what info I was looking for). I've got so many projects, I would have liked to nip that one in the bud quickly if I could. If not, I'll just take the time to remove all of the old wires and install new ones.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
