Re: Wiring on a Farmall 140 12v Conversion
Posted by Janicholson on January 04, 2014 at 18:16:32 from (69.146.159.98):
In Reply to: Re: Wiring on a Farmall 140 12v Conversion posted by Jon Hagen on January 04, 2014 at 17:26:05:
I have no contest with what you are saying. I also know that many issues have surfaced here on YT related to the one wire systems. Yours (and your supplier) might have the answer, but I still relate to the three wire approach, and recommend it due to the fact that the person doing the conversion just might get the one that does discharge the battery. With respect, Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
