Re: Wiring for farmall A
Posted by John T on January 04, 2014 at 19:02:36 from (108.106.110.208):
In Reply to: Wiring for farmall A posted by Farmall-h on January 04, 2014 at 13:55:44:
A battery powered coil ignition only draws like 4 amps and a Mag (subject to mags specs and RPM) is probably even less, so 20 or less gauge would likely work fine, although Id still want a big enough stranded wire just for its strength and flexibility. Stick a 16 gauge on if you like it will for darn sure have plentyyyyyyyy of ampacity but also be fairly strong.
John T
