Re: SM Engine Oddity, Goin' In!
Posted by Bob M on December 13, 2000 at 16:04:45 from (172.138.55.82):
In Reply to: SM Engine Oddity, Goin' In! posted by Pete on December 13, 2000 at 15:03:10:
Pete - 4-2-1-3 firing order merely says the distributor's installed 180 degrees out. No problem with that, so long as the wires are installed accordingly. Here's a couple more things to try before you tear into the motor too deep (presuming the distributor cap, rotor, etc are in good shape):
1 - Install a new set of D-21 or C-86 plugs. Also replace the plug wires with solid copper wires you've not already done so (do NOT use radio surpression wires!)
2 - If it's still backfiring out of #1, run a compression test on all 4 cylinders. If you find any of them low, pull the valve cover and reset the valve clearances to spec.
Good luck!
Post A Followup
: Re: Re: SM Engine Oddity, Goin' In!
