A one wire is easily changed back to its original configuration by replacing the regulator with a stock regulator. They are cheap on line, and easy to R&R. Putting sense, and lamp circuit wires on it the way it is might work, but also might not, depending on what modifications were made to make it "one Wire". I would wire up the new one (it will work) and replace the VR in the existing Alt. and save it as a reserve, or other application. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
