Re: Farmall H Fire out of muffler
Posted by glennster on January 05, 2014 at 16:26:43 from (99.90.9.201):
In Reply to: Farmall H Fire out of muffler posted by LaMar Indiana Country Man on January 05, 2014 at 05:59:00:
just for grins, pull the distributor cap off and give the rotor a flick and see if the centrifugal advance is working, or if has froze up. the tractor should be timed static ie engine off and points just starting to open at tdc. as soon as the engine starts, the distributor will advance. if it is stuck and not advancing, the timing will run retarded, causing the muffler and manifold to glow red. i had a minnie moline doing this. if you have a timing light, toss it on and see what the timing is doing with the engine running.
