Re: FARMALL 450 GAS
Posted by D Slater on January 05, 2014 at 19:04:04 from (184.14.185.1):
In Reply to: FARMALL 450 GAS posted by S2710 on January 05, 2014 at 17:58:53:
Some guesses, the bolt backed out retaining the IPTO driven gear to the lower shaft or gears have bad teeth. If the noise stops when the main clutch is disengaged scratch the above.
T/A clutch pressure plate failed with loose parts, Nut backed off that holds the T/A clutch carrier to the T/A unit.
