Re: over bore 46 farmall m
Posted by mattwillson on January 06, 2014 at 03:52:51 from (24.114.65.134):
In Reply to: Re: over bore 46 farmall m posted by Keith wager on January 05, 2014 at 18:14:01:
Hi, I'd say she's a bit low on compression. My 1950 with a 8777 head has 85psi. Probably the cheapest way to get more hp out of it will be to turbocharge it. I did that to mine and I like it. BTW, don't put a larger venturi in the carb, the #27 works better than a #29. I might try a #25 as well and see if it helps on the bottom end.
