Posted by mkirsch on January 07, 2014 at 05:57:24 from (65.199.189.6):
In Reply to: 2 Bottom Plow posted by Dave8N in Pa on January 06, 2014 at 09:25:30:
If by "parts" you mean wear parts like shares, moldboards, shins, landsides, etc... You do NOT want a stock Little Genius #8 if you plan on doing a lot of plowing!
Wear parts are NOT readily available for the old "quick change" or "blacksmith" bottoms. Most parts are also not readily available for the "Plow Chief" style bottoms.
The only IH plow parts that are still available are for the modern "Super Chief" style bottoms.
The one saving grace in the whole deal is that the bolt pattern for mounting the bottoms to the plow beams is the same all the way up from the Little Genius to the plows being made today. You can find a modern parts plow with Super Chief bottoms on it, and transfer them to the Little Genius plow frame. That gives you the period-correct plow look, and modern plow parts availability.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
