Engine swap from 666 to 656
Posted by raltn on January 07, 2014 at 07:34:55 from (50.142.97.75):
Can a 666, 686 diesel engine bolt right up in a 656 gas for a re power job or is this a big deal. Will the same clutch work(gear drive not hydro) Also what is a good source for a used/rebuilt 686 engine for the swap and what do they run cost wise. Thanks.
