Posted by caseyc on January 07, 2014 at 11:29:30 from (75.102.189.131):
In Reply to: 966 power steering posted by craig reavley on January 07, 2014 at 10:48:04:
After changing the hydraulic filter and making sure the system is full, if it still doesn't work then over fill it by 5 gallons. If it works then there is a seal out on the MVC pump not allowing it to prime. Just run it 5 gallons over unless you want to replace the pump. If that still doesn't work I would completely drain the whole system and fill with new HY-TRAN. HY-TRAN is designed to absorb moisture. After so many years it is "full" and the pump freezes up when below 32*. Fresh fluid will cure that. If you need to get it somewhere warmer to work on it put a knipco heater aimed right below the drivers side battery. That will thaw out the pump to get you moving.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
