Re: Farmall H Sleeve Puller
Posted by El Toro on January 07, 2014 at 12:06:52 from (96.244.7.206):
In Reply to: Farmall H Sleeve Puller posted by Brady Miller on January 07, 2014 at 11:44:08:
Can you measure the cylinder bore diameter of the block with the old sleeve installed? You may be able to measure the block bore after removing the piston and connecting rod. If the sleeve doesn't extend all the way down to the bottom of the block. Hal
PS: Use a pair of dividers to get a close measurement.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
